"A problem occurred..." Message on Test
Postby genelang » Tue Oct 30, 2012 2:06 pm
While running a "Test" on one particular Resource, I get the following message In the Test Results Details, "A problem occurred while trying to parse the directory listing into a list of remote files. Although GoAnywhere successfully connected to the server, the tasks using this resource may not function properly."
This Resource does contain many folders and varied data.
And, in fact, when I try to use this Resource in a Project, it never finds any files - even though they are readily available through other software like WS-FTP.
Does anyone know what causes this problem or have any hints as to what to correct in GoAnywhere and/or the Resource? I am running 4.2 from an iSeries V5R4.
genelang
Re: "A problem occurred..." Message on Test
Postby Support_Julie » Thu Nov 01, 2012 4:50 pm
The default list parser is UNIX. Normally you will see this error when the server you are trying to connect to is a Windows server. Try changing the List Parser for the resource to Windows.
Julie
Software Support
Linoma Software
Support_Julie
Support Specialist
Postby genelang » Fri Nov 02, 2012 12:00 pm
That was it! Thanks for the tip.
genelang
Postby PamDunn » Tue Dec 03, 2013 3:35 pm
I had the same issue, so I checked with the vendor who is receiving my information. I changed to UNIX, but it still did not solve the problem.
PamDunn
Postby Support_Rick » Wed Dec 04, 2013 11:37 am
Pam,
It could be that the user has it configured differently. There are other options on the List Parser. Try each until you find one that will allow you to parse the file list correctly.
If you're still having issues, please contact our Support Team by email: Support@Linoma.com
Or call our Support Desk at 800/949-4696
Sr. Product Specialist
Support_Rick
Support Specialist
Return to Community Forum
Who is online
Users browsing this forum: No registered users and 1 guest
