Calling .NET executable from Project
Postby jgelinas » Mon Jun 17, 2013 2:35 pm
Is this possible? If so, what is the syntax? Are there any interprocess communication capabilities?
jgelinas
Re: Calling .NET executable from Project
Postby Support_Rick » Mon Jun 17, 2013 4:39 pm
GAD is designed to handle execution of local executable programs. With this being said, if your .NET program is executable from a command prompt on the system that you have GAD installed on, then you should be able to execute the .NET from within a project.
Sr. Product Specialist
Support_Rick
Support Specialist
Postby jgelinas » Thu Jun 20, 2013 8:22 am
Any stipulations on where the executable should be located when called? Should it be on the GoAnywhere box or can it be on another server?
jgelinas
Postby Support_Rick » Thu Jun 20, 2013 9:02 am
There are no stipulations on where the executable has to reside. You will give it the full path to the program in the task, as well as the "current directory".
These called tasks are for local jobs only. Meaning, native to the GAD Installed Server.
Support_Rick
Support Specialist
Return to Community Forum
Who is online
Users browsing this forum: No registered users and 3 guests
