If statement: Check if folder does NOT exist.
Postby acascianelli » Tue Nov 19, 2013 3:51 pm
Looking to write a small if statement to see if a folder exists, and if it does not go ahead a create it. One caveat is that the foldername contains a variable. Here's what I got so far but it isn't working. Would appreciate a little assistance...
<timestamp version="1.0">
     <format outputVariable="currentDate" pattern="yyyyMMdd" />
</timestamp>
<if label="if: folder exists" condition="${FileInfo(&apos;/opt/Linoma_Software/GoAnywhere_Services/share/webdocs/MDT/Datamail/Archived/${currentDate}&apos;):exists == false}" logLevel="debug">
     <mkdir dir="/opt/Linoma_Software/GoAnywhere_Services/share/webdocs/MDT/Datamail/Archived/${currentDate}" version="1.0" />
</if>
acascianelli
Re: If statement: Check if folder does NOT exist.
Postby Support_Rick » Tue Nov 19, 2013 4:10 pm
Tony,
Just remove the IF statement and just do the MKDIR. Just change it to ignore the error if the folder already exists. That way you'll see the MKDIR in the job log, but it will tell you if the folder was created or not. And, more importantly, continue processing either way, by making sure the folder already exists or creating when needed.
<mkdir dir=".../Archived/${currentDate}" onError="continue" version="1.0" />
Sr. Product Specialist
Support_Rick
Support Specialist
Postby acascianelli » Tue Nov 19, 2013 4:15 pm
Thanks Rick.
I was trying to be fancier than I needed to be I guess. Seems to be a common problem I'm running into today...
acascianelli
Postby acascianelli » Wed Nov 20, 2013 11:15 am
Is there any way to have the error message in the job log suppressed in the event that the folder is already present?
acascianelli
Postby Support_Rick » Wed Nov 20, 2013 11:30 am
You can suppress the message by changing the loglevel ... like so.
<mkdir label="Create Dirs" dir="...\MyDir\MySubDir" version="1.0" logLevel="silent" onError="continue" />
But, this would remove it altogether. Normal and Verbose might give you different values. Might want to check them out as well.
Support_Rick
Support Specialist
Return to Community Forum
Who is online
Users browsing this forum: Bing [Bot] and 1 guest
cron
