XML Data Interchange with GoAnywhere
Postby Support_Sai » Thu Jun 04, 2009 3:20 pm
A sample project is below.
Project#1 Creating header-detail style XML document using data from multiple relational database tables
<project name="Outbound" mainModule="Main" version="1.0" logLevel="debug">
      <sql label="Connect to DB" resourceId="Production">
         <query label="Get Orders" outputVariable="orders">
            <statement>SELECT
   ORDNUM,
   ORDDATE,
   TOTAMT,
   CUSTNAME,
   ADDR1,
   ADDR2,
   CITY,
   STATE,
   ZIP
FROM
   GADEMO.ORDERS
ORDER BY
   ORDNUM</statement>
         </query>
         <query label="Get Line Items" outputVariable="lineitems">
            <statement>SELECT
   GADEMO.LINEITEMS.ORDNO,
   GADEMO.ITEMS.ITMNO,
   GADEMO.ITEMS.ITMNAME,
   GADEMO.LINEITEMS.PRICE
FROM
   GADEMO.ITEMS,
   GADEMO.LINEITEMS
WHERE
   GADEMO.LINEITEMS.ITMNO = GADEMO.ITEMS.ITMNO
ORDER BY
   GADEMO.LINEITEMS.ORDNO</statement>
         </query>
      </sql>
      <xmlWrite outputFile="C:\Program Files (x86)\Linoma Software\GoAnywhere2_0\userdata\documents\root\webinar-xml-orders.xml" whenFileExists="overwrite" defaultTrim="right" defaultTimestampFormat="yyyy-MM-dd&apos;T&apos;HH:mm:ss">
         <header>&lt;?xml version=&quot;1.0&quot; encoding=&quot;UTF-8&quot; ?&gt;</header>
         <element name="orders">
            <forEach inputRowSetVariable="${orders}" sorted="ascending">
               <element name="order">
                  <attribute name="orderNumber" value="${orders[1]}" />
                  <element name="date" value="${orders[2]}" />
                  <element name="totalAmount" value="${orders[3]}" />
                  <element name="shipTo">
                     <element name="name" value="${orders[4]}" />
                     <element name="address">
                        <element name="line1" value="${orders[5]}" />
                        <element name="line2" value="${orders[6]}" />
                        <element name="city" value="${orders[7]}" />
                        <element name="state" value="${orders[8]}" />
                        <element name="zip" value="${orders[9]}" />
                        <element name="country" value="US" />
                     </element>
                  </element>
                  <forEach inputRowSetVariable="${lineitems}" sorted="ascending">
                     <if test="${lineitems[1]} eq ${orders[1]}">
                        <element name="item">
                           <attribute name="itemNumber" value="${lineitems[2]}" />
                           <element name="name" value="${lineitems[3]}" />
                           <element name="price" value="${lineitems[4]}" />
                        </element>
                     </if>
                  </forEach>
               </element>
            </forEach>
         </element>
      </xmlWrite>
Project#2 Parse an XML document and import the data into a relational database
<project name="Inbound" mainModule="Main" version="1.0" logLevel="debug">
      <xmlRead label="Parse Orders XML" file="C:\Program Files (x86)\Linoma Software\GoAnywhere2_0\userdata\documents\root\webinar-xml-orders.xml" defaultTimestampFormat="yyyy-MM-dd&apos;T&apos;HH:mm:ss">
         <rowset name="orders">
            <column index="1" value="/orders/order/@orderNumber" name="OrderNumber" type="INTEGER" />
            <column index="2" value="/orders/order/date" name="OrderDate" type="TIMESTAMP" />
            <column index="3" value="/orders/order/totalAmount" name="TotalAmount" type="NUMERIC" />
            <column index="4" value="/orders/order/shipTo/name" name="CustomerName" />
            <column index="5" value="/orders/order/shipTo/address/line1" name="AddressLine1" />
            <column index="6" value="/orders/order/shipTo/address/line2" name="AddressLine2" />
            <column index="7" value="/orders/order/shipTo/address/city" name="City" />
            <column index="8" value="/orders/order/shipTo/address/state" name="State" />
            <column index="9" value="/orders/order/shipTo/address/zip" name="Zip" />
         </rowset>
         <rowset name="lineitems">
            <column index="1" value="/orders/order/@orderNumber" name="OrderNumber" type="INTEGER" foreignKey="true" />
            <column index="2" value="/orders/order/item/@itemNumber" name="ItemNumber" type="INTEGER" />
            <column index="3" value="/orders/order/item/price" name="ItemPrice" type="NUMERIC" />
         </rowset>
      </xmlRead>
      <sql label="Connect to DB" resourceId="Production" autoCommit="true">
         <query label="Clear Line Items">
            <statement>delete from wpsai.lineitems</statement>
         </query>
         <query label="Clear Orders">
            <statement>delete from wpsai.orders</statement>
         </query>
         <query label="Insert Orders" inputRowSetVariable="${orders}">
            <statement>INSERT INTO WPSAI.ORDERS
   (ORDNUM, ORDDATE, TOTAMT, CUSTNAME, ADDR1, ADDR2, CITY, STATE, ZIP)
VALUES
   (?, ?, ?, ?, ?, ?, ?, ?, ?)</statement>
         </query>
         <query label="Insert Line Items" inputRowSetVariable="${lineitems}">
            <statement>INSERT INTO WPSAI.LINEITEMS
   (ORDNO, ITMNO, PRICE)
VALUES
   (?, ?, ?)</statement>
         </query>
      </sql>
Project#3 Calling a web service using SQL Task, Write XML Task and HTTP Task
<project name="Call Web Service" mainModule="Main" version="1.0">
      <createWorkspace />
      <sql resourceId="Production">
         <query outputVariable="data">
            <statement>select zipcode from gademo.websrvdemo where company = &apos;Linoma Software&apos;</statement>
         </query>
      </sql>
      <xmlWrite outputFile="SOAPRequest.xml">
         <element name="soap12:Envelope">
            <attribute name="xmlns:xsi" value="http://www.w3.org/2001/XMLSchema-instance" />
            <attribute name="xmlns:xsd" value="http://www.w3.org/2001/XMLSchema" />
            <attribute name="xmlns:soap12" value="http://www.w3.org/2003/05/soap-envelope" />
            <element name="soap12:Body">
               <forEach inputRowSetVariable="${data}">
                  <element name="GetWeatherByZipCode">
                     <attribute name="xmlns" value="http://www.webservicex.net" />
                     <element name="ZipCode" value="${data[1]}" />
                  </element>
               </forEach>
            </element>
         </element>
      </xmlWrite>
      <http host="www.webservicex.com">
         <postRawData uri="/WeatherForecast.asmx " inputFile="SOAPRequest.xml" contentType="application/soap+xml; charset=utf-8" responseBodyDestination="file" responseBodyFile="C:\Program Files (x86)\Linoma Software\GoAnywhere2_0\userdata\documents\root\weather-report.xml" whenResponseBodyFileExists="overwrite" />
      </http>
Support_Sai
Return to Example Projects
Who is online
Users browsing this forum: Bing [Bot] and 1 guest
cron
