Using Public/Private Key created in different PGP
Postby Melbek » Thu Jul 31, 2014 8:22 am
We were using ArticSoft PGP previously and we would like to convert to Go Anywhere PGP, so my question is, is that possible to use Public/Private Key created by ArticSoft PGP so we don't have to distribute our public key to the client again.
Thanks
Melbek
Re: Using Public/Private Key created in different PGP
Postby Support_Rick » Thu Jul 31, 2014 11:11 am
If ArticSoft allows you to export your Public/Private keys, you should be able to import them directly into GoAnywhere PGP by utilizing the "Import Keys" function under the OpenPGP Keys tab. This should load the current keys you are using and allow you to use them for Encrypting/Decrypting.
Sr. Product Specialist
Support_Rick
Support Specialist
Postby Melbek » Thu Jul 31, 2014 12:58 pm
Not sure why it is asking me to enter a Private key password for Decrypting, the previous software wasn't asking that. just wondering if i can do anything.
Thanks
Melbek
Postby Support_Jon » Thu Aug 07, 2014 12:56 pm
What kind of key (format) was the existing one created in?
Please confirm that when you exported the keys from your existing software that you got the full key pair (public & private) and not just one of them.
Thanks - Jon
Support_Jon
Support Specialist
Return to GoAnywhere OpenPGP Studio
Who is online
Users browsing this forum: No registered users and 1 guest
cron
